Introduction: Rainbow Loom Ladder Bracelet
This bracelet is pretty easy to make if you know how to use the loom. This isn't an original design.
You'll need:
•a rainbow loom or any other loom
• rubber bands
• a hook
• C-clip or S-clip
Now lets get started! (-:
You'll need:
• rubber bands
• a hook
• C-clip or S-clip
Step 1: Placing the Bands
Start by placing your loom with the arrows pointing away from you. Now start placing your bands around the border like in the picture.
Step 2: Horizontal Bands
Now. place horizontal bands all the way up except skip the first pegs.
Step 3: Vertical Bands
Now place your next bands up in the center pegs as if you're making a single chain. Then turn your loom so the arrows are pointing towards you.
Step 4: Cap Band
Now place a cap band on your peg.
Step 5: Looping
Now take your hook and begin looping the center bands until you reach the end.
Step 6: More Horizontal Bands
Now place more horizontal bands until you reach the top.
Step 7: Hooking the Sides
Now go back to the cap band and using your hook, take the top band and hook it to the left. Then hook the other side to the right.
Step 8: Hooking the Sides
Use your hook to loop the sides up to the top. Do the same to the other side.
Step 9:
When you get to the end, hook the end bands toward the middle.
Step 10: Finishing Your Bracelet
Now take your hook and place it underneath all the bands on that last peg and pull a single rubber band through it. Then you can start pulling up your bracelet.
Step 11: Add Your Extension
Now you can add your extension. Then add a clip to the end and you're finished!
