Introduction: Rainbow Loom Ghost
A cute little pac-man inspired ghost charm on the loom
Step 1: You Will Need...
You will need
bands of your choice of colour for the ghost
two different colored bands for the eyes
the tool for looping ( you can use your fingers if you want to )
Step 2: The Shape
take your first two bands and place them like a triangle on the top of the board. then go three bands down, and then do a bottomless triangle at the bottom. then twist your eye bands around a body band four times. then place them at the top, just under the triangle.then strech a single band under the eyes, and once under that. this is what holds it together.
Step 3: Cap Bands
put a triple twist cap band on the three bottom points
Step 4: Looping
You are now ready to loop
Step 5: Looping, No.2
loop your bands as so
loop the two bottom points up through themselves. thats probably the second hardest part. now just loop lime a single chain, until you get to the top.
Step 6: Making the Hold
now is the hard part. take one band, and pull it straight. now insert it into the very top of your ghost, and pull it so its full, but holding it together. now pull it off the loom, ang you are done!
