Introduction: Raspberry PI-based, Phone-controlled, First-person-view Lawn-mower.
Meet Lawny! It’s a lawn mower with a first-person view camera that allows you to cut grass while controlling a remote-controlled robot!
I’ve built it using a Raspberry PI, H-Bridge, electric motor, and camera. It can be controlled from a mobile phone or a desktop.
The project's main idea is to control a lawnmower using a phone and see the exact same picture as a lawnmower.
Here is the full video of its creation and all the concepts that are described in this article:
https://www.youtube.com/watch?v=4OQUo0V-8QY
- Raspberry PI 5 https://nerdythings.io/url/raspberry-...
- Raspberry Pi Camera Module 3 https://nerdythings.io/url/raspberry-...
- Windshield Wipers Motor https://nerdythings.io/url/wind-shiel...
- Grass cutter electric motor https://nerdythings.io/url/motor-12v-30w
- Relay https://nerdythings.io/url/relay-5v
- Wires https://nerdythings.io/url/jumper-wires
- H-Bridge https://nerdythings.io/url/h-bridge-12v
- Steel Razors Trimmer Head https://nerdythings.io/url/steel-trim...
- Power Bank https://nerdythings.io/url/power-bank
- 12V 9AH battery https://nerdythings.io/url/battery-12...
- A rear wheel https://nerdythings.io/url/powertec-w...
- Front Wheels (7inch) https://nerdythings.io/url/lawn-mower...
- Craftsman instruments https://nerdythings.io/url/craftsman-...
- Grooved Step Drill Bit Set https://nerdythings.io/url/step-drill...
- Soldering https://nerdythings.io/url/soldering-kit
Step 1: System Design
I have a Steel Razors Trimmer Head. If I add an electric motor, it will be a grass cutter. The motor rotates the blades, and they cut the grass. Simple.
If I want to control the motor, I need a relay and a controller. In my case, I used a Raspberry PI 5 (because I had it). However, any Raspberry device could support pulse width modulation and a camera.
That will be a static lawn mower. But I want to cut grass everywhere, not just in one spot, and I want to be able to turn the mover left and right.
So I am adding two more electric motors. The construction will be heavy, so I need power, not speed, and I will use windshield wiper motors from a real car.
The first limitation is that I need two Pulse Width Modulation channels to control a single motor. But I have two motors, which means that I need four channels. To solve this problem, I am adding two more relays to switch the signal between pins. Further, I need to see where the lawn mower is going, so I am adding a camera module to the Raspberry PI. Additionally, I need some power sources. To prevent power drop elements that consume a lot of current, I will use a separate battery for the motors and a power bank for the Raspberry PI and electronics.
And finally, I will control this system from a mobile phone with a cross-platform application through wi-fi.
Step 2: Cutter Box
The cutter box is made from plywood. It has a hole for the motor in the middle.
Step 3: Mower Body
The next is to create a body. I am adding a few more surfaces to make that mower move.
Step 4: Join Cutter Box
Connect the cutter box with the body using slides.
Step 5: Paint
Paint all surfaces
Step 6: Place Electric Components
Place electronic components:
- 1 Raspberry PI 5 https://nerdythings.io/url/raspberry-...
- 2 Windshield Wipers Motor https://nerdythings.io/url/wind-shiel...
- 1 Grass cutter electric motor https://nerdythings.io/url/motor-12v-30w
- 3 Relay https://nerdythings.io/url/relay-5v
- 2 H-Bridge https://nerdythings.io/url/h-bridge-12v
- 1 Power Bank https://nerdythings.io/url/power-bank
- 1+ 12V 9AH battery https://nerdythings.io/url/battery-12...
Step 7: Add Wheels
- 1 A rear wheel https://nerdythings.io/url/powertec-w...
- 2. Front Wheels (7inch) https://nerdythings.io/url/lawn-mower...
Step 8: Add a Blade
