Introduction: Raspberry Pi LM75BIMM Temperature Sensor Python Tutorial
LM75BIMM is a digital temperature sensor incorporated with thermal watchdog and has two wire interface which supports its operation upto 400 kHz. It has an over temperature output with programmable limit and hystersis. Here is the demonstration with a java code using Raspberry Pi.
Step 1: What You Need..!!
Step 2: Connections
Take a I2C shield for raspberry pi and gently push it over the gpio pins of raspberry pi.
Then connect the one end of I2C cable to LM75BIMM sensor and the other end to the I2C shield.
Also connect the Ethernet cable to the pi or you can use a WiFi module.
Connections are shown in the picture above.
Step 3: Code
The python code for LM75BIMM can be downloaded from our github repository- Dcube Store
Here is the link for the same :
https://github.com/DcubeTechVentures/LM75BIMM/blob/master/Python/LM75BIMM.py
We have used SMBus library for python code, the steps to install SMBus on raspberry pi is described here:
https://pypi.python.org/pypi/smbus-cffi/0.5.1
You can also copy the code from here, it is given as follows:
# Distributed with a free-will license.
# Use it any way you want, profit or free, provided it fits in the licenses of its associated works.
# LM75BIMM
# This code is designed to work with the LM75BIMM_I2CS I2C Mini Module
import smbus
import time
# Get I2C bus
bus = smbus.SMBus(1)
# LM75BIMM address, 0x49(73)
# Select configuration register, 0x01(01)
# 0x00(00) Continous conversion, Normal operation
bus.write_byte_data(0x49, 0x01, 0x00)
time.sleep(0.5)
# Read data back from 0x00(0), 2 bytes
# Temp MSB, Temp LSB
data = bus.read_i2c_block_data(0x49, 0x00, 2)
# Convert the data to 9-bits
cTemp = (data[0] * 256 + (data[1] & 0x80)) / 128
if cTemp > 255 :
cTemp -= 512cTemp = cTemp * 0.5
fTemp = cTemp * 1.8 + 32
# Output data to screen
print "Temperature in Celsius is : %.2f C" %cTemp
print "Temperature in Fahrenheit is : %.2f F" %fTemp
Step 4: Applications..:
LM75BIMM is ideal for a number of applications including base stations, electronic test equipment, office electronics, personal computers or any other system where temperature monitoring is critical to performance. Therefore, this sensor has a pivotal role in many of the highly temperature sensitive systems.
