Introduction: Rc Depron Boeing 737-500 40mm Edf
I have a passion for Rc airliners, There are not many available build your own kits, mainly only almost ready to fly kits, so ive designed my own Boeing 737-500. It is built from depron, lite ply and balsa. Its been designed for 5 channel radio.
Step 1: The Plans
The first step was to locate some good plans to build from. There was none i only found a 3 view cad drawing on the official website in the airport planning, then i set about creating the cross sections.......
I designed this to be cut out on my cnc router, i have since converted it with added co2 40 watt laser.
Step 2: Cutting and Assemble
Once the parts are cut out, it is a slot together construction, the only templates that are not supplied is the nose and tail sheet pattens, these are easily enough recreated by curving some depron and trimming to fit.
Step 3: Assemble
once the nose is sheeted simply add the nose /cockpit blocks and sand to shape. the same with the tail, the wings are held on with magnets.
Step 4: Assemble the Wing and Edf Housing
the wing simply slots together, a carbon fiber rod 2mm diameter gives the wing strenght, the edfs housing are simply to assemble and sheet.
Step 5: Finishing
the model was designed for retracts for the scale look. you may wish to ditch them for weight saving, I finsihed the model in the british airways theme, totsl weight with 3 cell lipo is 450g.
2 servos in the wings, 1 per elevator and rudder, 1 for steering, retracts not hooked up for maiden flight.
