Introduction: Rc Crest Car
About: Tsc stands for totallysupercreaitve. Please if you like what I make follow me! I like riding any thing with a engine or motor. I also like build weedeater bikes and chainsaw bikes also mini choppers. I be…
It's Here a Rc tooth paste car! How to make it well that's why I'm here so go to step one and I will tell you what you need. Oh wait I'm for getting to tell you how I got the Idea well I was on thinkgeek.com ,and they had rc car or someing I don't really rember what it was ,but any way I started to look for some thing out of my juck stuff. I could not find any thing good ,but then I found a tooth paste case! ,and  so on! I'm enter in this in the Epilog Challenge  so if you like this please vote! If you like what I build please Subscribe to me!!
Step 1: Supplies
This is a list of supplies that you need:
Empty crest tooth paste container,
Hot glue sticks and a hot glue gun,
Air hog Thunder rc truck(You can get them at walmart, and maybe you can get them target I not sure),
A razaor,
Water,
 Controller to your Air hog Thunder rc truck ,
Three triple a batterys,
marker,
Scissors,
Step 2: Remove
So we need to get the body off now on the side their should be a clip looking thing now their is a little bit of glue in between the clip and the main body so take your razaor and push to between the glue makeing it so you can take the body off  repeat  this step with the other side.
Step 3: Clean!
Now make sure you get all the tooth paste out! Put water down in to the tooth paste container then push both side in and watch the tooht paste ,and water come out repeat til it like as empty as you can get it.
Step 4: Draw
Mark out the out line of were the middle of the car's main body will go on the crest tooth paste container.Like put the car on the bottem of the crest tooth paste container then make a  mark at the front and at the back then take the car off  ok ow draw a line from the front mark ,and  back  mark and  do this with both sides of the marks then cut out your out line.
Step 5: Glue
Now heat up your glue gun and fill the front and back up with hot glue then a thin layer of hot glue a cross the middle.
Step 6: Almost Done!
OK the hole in the crest tooth paste container put the hole over the middle of the car then glue it in place. You can glue it down were open spots are between the hole in the crest tooth paste contairner and between the car.
Step 7: Done!
Your done put the batterys in the controller  then  charg the crest car up ,and drive her around!!
