Introduction: Release a Bouncing Cardboard Disc
Fling a lightweight disc to bounce along surfaces. Invent a compass made of Strawbees beams, then draw circles on a sheet of cardboard. After cutting the disc, attach a rubber band and release to project the aerodynamic disc through the air!
- Blue 1-leg connector x 4
- Yellow 2-leg connector x 1
- Yellow straw (4 cm) x 1
- Orange straw (8 cm) x 1
- Rubber band x 1
- Corrugated cardboard box to be cut down into sheets
- Scissors
- Thin marker
- Optional: Ruler
If you don't have Strawbees connectors and straws, use a compass to draw 2 circles on the cardboard sheet. The inner circle's radius is 7 cm. From the edge of the outer circle's radius measures at 10 cm.
To get Strawbees connectors and precut straws, you can purchase the STEAM School Kit (for up to 30 students) or STEAM Starter Kit (1 per student).
Vocabulary
- Radius - A line segment extending from the center of a circle
Step 1: Make a Compass
Step Pieces
- Blue 1-leg connector x 3
This beam made from Strawbees straws and connectors transforms into a drawing compass. The orange straw is longer and will be used to draw the outer circle of the disc. Leaving the yellow straw for drawing the inner circle.
Click the 1-leg connector into the 2-leg connector for the center of the beam. Then fit the straws on the legs of the 2-leg connector. Attach the remaining 2 blue 1-leg connectors on the ends of the straws.
Step 2: Trim a Cardboard Sheet, Poke a Hole, Then Attach Compass
Step Pieces
- Cardboard sheet
- Scissors
Poke a hole in the center of the sheet. Then stick the compass with the leg of the blue 1-leg connector through.
Step 3: Lock the Compass on the Back Side of Sheet
Step Pieces
- Blue 1-leg connector x 1
Secure the compass by locking a blue 1-leg connector on the other side of the sheet.
Step 4: Draw the Inner Circle With Compass
Step Pieces
- Marker x 1
Point a marker down through the hole of a 1-leg connector attached to the yellow straw. Then draw a small circle. The hole should be parallel to the surface as the hole for the marker to clearly draw down through.
Step 5: Draw the Outer Circle
Step Pieces
- Marker x 1
Point a marker down through the hole of a 1-leg connector attached to the orange straw. Then draw a small circle.
Step 6: Cut the Disc Out
Step Pieces
- Scissors x 1
Cut the cardboard from the inner circle and the outside of the disc out.
Step 7: Draw a Tiny Triangle on the Outside of Disc
Step Pieces
- Marker x 1
Step 8: Cut Tiny Triangle Out
Step Pieces
- Scissors x 1
Drawing this tiny triangle is going to be a notch for holding the rubber band to release.
Step 9: Launch Your Disc With a Rubber Band
Step Pieces
- Rubber band x 1
Hook a rubber band on the notch. Then launch your disc!
