Introduction: Removing Rivets
About: I used to work for instructables.com, now I just make stuff. // follow me to see what I'm up to: https://www.echoechostudio.com
I have just begun the restoration process of my tiny fiberglass trailer. When I pulled the interior lights down off of the hull, there were multiple rivets that were holding them in place, that now needed to get removed.
I gave each rivet a good tug with a pair of pliers to make sure which ones actually needed to get removed. (all of them :P)
I figured out which of my drill bits was the same size as the hole in the rivet, and then used that bit to drill out the rivets.
In summary:
1)Assess what size drill bit your rivets will need.
2)Drill out the rivet
3)Patch your hole (I'm patching this fiberglass hull with a 5 minute quick-set epoxy, the holes these rivets left behind are very small)
If you have questions, feel free to comment.
