Introduction: Repair a Gopher Reaching Tool
Having bought two of these I was disappointed in how quickly the grip cups broke off. They were held on by self tapping screws into a hard plastic insert that crumbled. Let's fix it.
Step 1: Gather Materials
I figured I could put a screw through the cup and bolt it to the arm for a permanent fix.
I dug through my hardware hoard (everyone should have one) and found two small screws with matching nuts and lock washers. I also needed an eighth inch drill bit to drill through the cup.
Step 2: Drill Cups and Install Screws
I used the eighth inch drill bit without the drill to drill through the cup and pressed the screws through the cup.
Step 3: Bolt on the Cups
After removing the original screws put the cup bolt through the two holes in the grip arms add the lock washer and the nut and tighten. I added a drop of Loctite to keep it from coming loose with use.(you can also use nail polish or white out). That's it, now I can pick up the dog toys.
