Introduction: Repair Computer Keyboard
About: Jack of all trades, master of none, though ofttimes better than master of one..
Repair computer keyboard circuit using aluminium foil.
Step 1: Detect the Problem in Circuit Using Multimeter.
Disassemble your keyboard by unscrewing all screws in the bottom. You'll see three plastic sheets. Clean any previous liquid spills or dirt.
  • upper circuit sheet
  • middle plain plastic sheet
  • bottom circuit sheet
Using multimeter, detect the fault in circuit. It may take a while in detection, be patient. Isolate the problem and this step is done.
Step 2: Using Aluminium Sheet As Conductor.
Use microwave aluminium sheet. I used shisha smoke foil. Cut a strip to cover the faulty area in circuit sheet.
Step 3: Placing Aluminium Strip With a Drop of Glue.
See the red circle. I placed the aluminium strip in between lower and middle plastic sheet. If you've isolated the fault correctly and placed the aluminium foil without a short. Your keys should work now.
Good Luck ~
