Introduction: Repair a Weed Eater Trimmer Model FX26C
Hello!! This instructable is how to fix a WeedEater Gas String Trimmer Model FX265C.
Step 1: Disconnect the Spark Plug Wire
The first step in repairing a Weed Eater FX26C is to disconnect the spark plug wire.
Step 2: Open Air Filter Box
You crack open the air filter box to retrieve the air filter.
Step 3: Take Out the Air Filter
You then pull the air filter out of the seat.
Step 4: Then Change the Primer Bulb
Unscrew the primer bulb seat, and replace the primer bulb. Then screw the primer bulb and seat on.
Step 5: Cut Fuel Lines
Then you cut the fuel lines and pull them out of their connection points.
Step 6: Replace Fuel Lines
Then you replace the fuel lines with new ones.
Step 7: Get Going!!
Now add 40:1 premixed fuel into the tank, and go test it.
Step 8: Thanks!!
Thanks For Reading. I hope that this helps.
