Introduction: Repairing a Toilet
my toilet was leaking from 2 spots and lacking bad. The 2 pics are of what broke the water line and the fill valve. the rubber seal on the fill valve was cracked and the lone had a pin hole in it
Step 1: Turn Off Water and Flush Toilet (VERY IMPORTANT!!!)
You'll get wet otherwise
Step 2: Drain the Tank and Hose
unscrew fill valve and drain into a bucket
Step 3: Start Assembly of New Fill Valve
pretty simple just make sure the rubber seal is tight and don't screw it too tight
Step 4: Attach Water Lines
In picture 5 is the adapter that was needed to fit the line on and in picture 1 I hooked up the drainage tube.
Step 5: Attach the Floater
after you get everything else together turn the water on and make sure it will stop at the fill line
Step 6: Make Any Necessary Adjustments
Do a few test flushes and now you're done
