Introduction: Replace Car Wing Mirror DIY on Fiat Panda. Save Up to 100€
You can see how to replace the car side driver mirror yourself for a Fiat Panda. First, we dismount the broken mirror, then we install the new mirror and finally we shoot the damage mirror.
It is very easy, save money, you only need a screwdriver, the replacement part (15-30€) and 10 minutes.
Step 1: Remove Plastic Cover
Remove the plastic cover from the ajustmen bar
Step 2: Unscrew From the Mirror Ajustment Bar
Unscrew the nut from the mirror ajustment bar
Step 3: Remove the Panel With
Use a screwdriver to remove the mirror panel
Step 4: Use an Screwdriver to Remove the Plastic Nut
Use an screwdriver to remove the plastic nut. Finish the work rotation with the fingers
Step 5: Remove the Broken Mirror
Remove the broken mirror
Step 6: Place the New Mirror and Insert the Plastic Nut
Place the new mirror and insert the plastic nut and screw it
Step 7: Insert and Fix the Panel
Insert and fix the panel
Step 8: Screw the Metal Nut and Tight It With the Screwdriver
Screw the metal nut and tight it with the screwdriver
Step 9: Put Back the Plastic Cover to the Adjustment Bar
Put back the plastic cover to the adjustment bar
