Introduction: Replacing the Distributor Without Using a Timing Light (Honda Civic 1999 D15B)
Continuing with my preventative maintenance program on my car, the 16 year old distributor in the engine will be changed out to a new unit in this instructable.
As per the Honda service manual, I began with the removal of the OEM distributor.
This instructable is about a distributor replacement without having to use a timing light to get the ignition timing as with the oem distributor.
Step 1: Removing the OEM Distributor.
I put a line on two of the distributor mounting flanges and then I took off the spark plug wires. Luckily the pics I took will guide me to put the wires back into place for the new one.
I removed the connector by prying the holding clip on the metal bracket.
Using the metal bracket I took measurements on the top and left bolt washers. The top bolt washer is 5mm from the flange edge. The left one is 7mm. Again I used the metal bracket on the distributor to steady my measuring tape.
Three bolts to remove and the distributor pulled out of the engine camshaft easily.
Step 2: Comparing the Old and New.
Before installing the new distributor I made sure to turn the shaft to line up as with the oem. See the last pic for that.
Step 3: Installing the New Distributor.
Step 4: Completion and Testing.
No need to spend money on a one use timing light! I hope this instructable has been helpful to fellow civic folks.
