Introduction: Resin Heart Necklace
From this tutorial you will get a necklace resin of various colors (it's depends to the pigment of the cartridge you can find!). A good manual dexterity is required for a good result.
The theme can be any, I chose the heart with the lock to be able to connect in a symbolic key to the closure , but the creations can be the most varied ! depends on your imagination ,
you need
silicone
talcum powder
Two-component resin
powder Laser Printer from empty cartridge
Sculpix paste
oven
baking paper
spatula
support for modeling sculpix
modelling tools
scotch tape
plastic gloves
brush
mini-drill
multiuse octopus for models
Step 1: The Model
the type of mold that we're going to do is quite true and exat, but it is important that subjects are predominantly bas-relief . To ensure that the locks of the necklace are functional is necessary that the hole where it will be inserted the dipstick respecting the correct proportions while the base of hole coupling must be of a larger diameter of the chain that went to choose
the modeling clay that I used to harden will then baked in the oven as shown in the manufacturer's instructions
Step 2: Laser Powder Pigment
i use this cheap trick for the pigments. Now we're going to extract the dust from the pigment laser printer cartridge, the color will be to your liking, I have taken the black, with a drill make a hole in the tank and remove the powder, attention!! is extremely volatile and dirty everywhere
Step 3: Silocon and Talc Powder Mold
we pass to the realization of the cast of silicone and talc
spread a thin layer of talcum powder on the baking paper and then squeeze over the silicone must be able to cover the models made
Step 4: Impression Mold
once created the mixture of silicone, gently insert the models
let dry it for 24h
Step 5: Extract and Strain
Now we are going to extract the casts and cut the chain I have used two segments of 25 cm
in casts empty're going to strain the two-component resin in the proportions 1: 1 as reported by the manufacturer's instructions
Step 6:
when the resin is not yet catalyzed, immerse perpendicularly into the groove of the crossbar for closing, one end of the chain previously cut
for this perpendiculary tick I used a multi tool for models
wait until the resin catalyses
extract copies
finish them and remove any burrs
Step 7: Realization of the Holes for the Chain
now need to create the holes needed to be able to insert the chain with the help of mini drill
realize a minimum dose of resin with which we will then secure the chain to the pendant and closures
Step 8: Fix the Ends
with the use of stencils we're going to fix vertically models with the holes facing up
then insert the respective ends of the chain secured with the resin and then let them harden
then we can have the pendent almost finish
Step 9: Personalize It
place on a piece of parchment paper our necklace
we are going to prepare a little more resin and this time together with the components A and B will also add the powder of the laser printer previously extracted in step 2
apply a few drops of black resin (or the chosen color) on the pendant and spread it evenly with the use of gloves to have better dexterity
trying to penetrate the color in the cracks
you can use all the colors extracted from laser cartridges
let dry and the pendant is complete!
Step 10: Also Only Powder
one can also use only the powder to create depth
once spread with the brush just remove the excess with paper
possibly fix it with spray fixative
