Introduction: Restore Vintage Stationary Bike
Hi guys today i will show you how I restored a stationary bike.
Model. slender bike vx3p
This is a very old stationary bike that had been neglected by its previous owners and stored outside.A friend of mine was planning on throwing it out one day, and i offered to help.
Step 1: Tools and Materials
I will use the minimum amount of tools on this , since most of the nuts and bolts have rust on them its better to replace it either way so i wont be using the right size bits but rather locking vise grips and wd40
1 flat head screwdriver
2 locking vise grips
Phillips screwdriver
sander ( and various grits of sand paper)
spray paint
primer
large plastic sheet( to cover area around bike when painting)
various rugs for cleaning
spray bottle
Step 2: Inspection
overall, there are numerous spots of rust and faded paint and damaged pieces. so here we go.
model sticker needs to be overhauled rusty tire cover needs to shine, the seat had to go. odometer needs to be cleaned . hand grips need to be replaced. seat post needs major shine. chain be replaced or deep clean. etc.. etc.. etc...
Step 3: Disassembly
Started with a knife.
Cut out the handle bar grips, because they were so old and cracked up .
Remove the timer and odometer and spedometer holder .
Loosen the bolt for the handlebar holder.
Slide out the handle bar.
Remove the bolt securing the seat to the seat post.
Remove the seat
Loosen the bolt securing the seat post to the frame.
Remove the seat post.
Remove screws securing the frame to the front tire.
Remove the nuts securing the tire to the front fork.
Remove tire.
Remove tire cover .
Loosen the double ring screws securing the front stem to the forks
pry out the stem
Remove supporting metal.
Step 4: Sanding Cleaning and Painting.
Buy new handle bar grips
Buy new seat.
sand off the rust off the seat post.
Sand off the rust from the handlebar
sand off the rust from the tire cover
clean off the uv damaged plexiglass off of the odometer
start with 400 grit sand paper and wet sand it.
progress to 800 and then a 1000 grit
and then polish it. and then spray a sealer on it
Clean the bike chain.In gasoline while brushing it with a metal brush
Sand and clean off any rust from the frame
Cover the whole area around the frame with a plastic sheet
spray a primer, then a paint of your choice. shiny gloss is preferred.
avoid over spraying to avoid tears of paint on the frame.
paint the timer and the odometer plastics .
Clean off and sand the rims of the tire.
Step 5: Finally , Put It All Together
so assemble all the parts together .
New seat.
New handlebar grips
replace some nuts and bolts
And there you have it.
