Introduction: Revolving Bookcase
About: I am a Marine Engineer in the RNZN (45 years done in various navies) and am looking forward to retirement!!! so I can do more messing about with tools
I wanted somewhere convenient to store my woodwork books and project files, however as always space is at a premium so I needed something compact that would utilize space to the utmost.
I figured that a "Lazy Susan" design would work best
Wood :- I used some old cupboard doors, 6mm plywood and a piece of 2x2 framing timber
14mm dowel
Screws
Lazy Susan
Paint
Tools :- Table saw, Drill, Driver, Jigsaw, Sander
Step 1: The Shelves
I had these solid cupboard doors that I had removed from an old kitchen some time ago. They were at my favourite price (free), they are solid oak.
I removed all the "furniture" from them (which I will save - just in case!)
I then cut them to 400mm square on the table saw.
Step 2: Centre Spindle
I cut a piece of 2x2 framing timber 700mm long (again this was free - rescued from a skip)
Step 3: Centre Shelf
Using a hole saw I drilled a 2inch hole in the centre shelf, then squared it off using a Jigsaw
Step 4: Centre Shelf Support
I took the piece of 2x2 and drilled 14mm holes in both planes and then inserted dowels which were glued into position.
note one dowel goes all the way through, and the other two abut it at the middle
Step 5: Fitting the Shelves
The middle shelf was "fed" onto the centre spindle and the bottom and top were screwed on to the ends of the spindle. A few measurements were taken to ensure that the shelves were parallel to each other.
Step 6: Book Retainers
I ripped some 1/2 inch strips from framing timber to act as retainers or stops for the books on the bottom and middle shelves, these were screwed in place.
Step 7: Lazy Susan
I bought a Lasy Susan attachment from Bunnings ($21 NZ) and screwed it to the base.
I then slapped a quick coat of paint on what I had done so far and allowed it to dry overnight.
Step 8: Plywood Retaining Strips
The following day I ripped some 40mm wide plywood retaining strips from 6mm exterior ply that I had been given by a neighbour and cut them to length, 3 for each side.
These were then screwed on. This gave the whole structure a lot more rigidity.
Step 9: All the Strips in Position and Paint
Once I had screwed all the retaining strips in position I gave it another quick couple of coats of paint and allowed to dry.
Step 10: And Add Books
Looks like I need to buy more books ............... any excuse!
