Introduction: Rick and Morty Figurines
My first project is an artistic one. I wanted to make something related to one of my favorite TV Shows and I saw this video on Youtube from a channel called Duke Doks.
  • 3D printed figurines
  • Sand paper
  • Primer
  • Paint
  • Varnish
Step 1: 3D Printing
First step is to 3D print the models. You can get them from the official page of the original designer:
Step 2: Sanding
The best way is using sandpaper. You can start with a rough one (400 grit) and them use softer ones (800, 1200 grit...)
Step 3: Priming
To finish covering the layers you can use primer. I used a spray one that it's easy to apply. After applying several layers it is recommended to sand them one more time in order to get a perfect surface.
Step 4: Painting
This is one of the most important steps. The quality of the paint is important. I used acrylic paint and applied it with a brush but the best way to paint them is using an airbrush.
Step 5: Varnishing
Finally, in order to protect the paint, I applied a couple of layers of varnish. This will protect the paint and the figurines will have a very nice finish. In my case, I used matte varnish to avoid any reflections and make the colours pop up.
Step 6: Original Project
The original project was made by a creator called Duke Doks. Here is his youtube video.
