Introduction: Rigged Dice
I made dice with a laser cutter out of acrylic the dice are weighted on the winning number 4,5,6 so it has a higher chance of it landing on that. how might i angel Estrada instruct certain to make some rigged dice using a laser cutter and acrylic so that they can have fun playing and winning dice.
we are going to need white acrylic for the materials. For tools, we will need a laser cutter and a computer, and maker case website, and a coral vector also. we will also need to use glowforge to operate the laser cutter.
Step 1: Build the Out Line of the Dice
go to https://en.makercase.com/#/ and go to "simple box".
then set the with, height, and depth as seen in the 2 pictures.
after on edge joints set it to fingers and adjust it to 0.3.
finally, press the download box and set kerf to 0.0025. then download the file as an SVG.
Step 2: Put in the Numbers and Export
go to https://app.corelvector.com/
then set with height to inches and 12x12.
after exporting your box from the maker case then you can add Eclipse until you have something the same as dice on each one.
then once you have all ur eclipse you can save ur final dice and export it as a SVG.
Step 3: Cut It Out
final step go to https://accounts.glowforge.com/users/sign_in and place your image on to the picture as seen on the picture and begin to cut it out.
Step 4: Put It Together
once cut out glue anything heavy to the number 1,2,3 only.
once you do that put all your dice together they should just go into place.
There you go finally you have some weighted rigged dice to get a bigger chance of landing of 4,5,6 the winning numbers
