Introduction: Robo Bank Man
About: Follow me on Instagram Leah2098
The Robo Bank Man is a great invention! This invention is made out of art and it's just like a piggy bank because there is a tiny cut that let's you put coins in! This robot is in disguise because people might think that it's just a robot made out of art with a piece of it not covered.
Step 1: Glue the Head
Take three pieces of wood ( you can use any shape. I used a square) and glue them together.
Step 2: Eyes
Take any small item for the eyes. I used little foam circle beads. And what you want to do is glue them to the wood. You can place them how you want to.
Step 3: Mouth
For the mouth, I used pipe cleaners. You can cut it to the size you want and form it anywhere you want.
Step 4: On the Top of the Head
If you want to, you can add extensions on the top of the head.I added a tall piece of wood and at the top of the piece of wood, I put a foam star bead. Then I glued it to the top of the head.
Step 5: Body
For the body, I took a regular size shoe box. I put the cap on the bottom an made a small hole in the middle.
Step 6: Taping the Sides
When I taped the sides I got duck tape and white tape and started taping the sides. It doesn't matter what tape you use because we will be covering it soon.
Step 7: Wrapping
After I taped the sides. I took some construction paper and started wrapping the sides. I used the colors yellow and purple. You don't want to cover the hole, but you don't want the hole to show.
Step 8: Taping the Head
Once you done wrapping, you want to either tape or glue the head. I tapped it.
Step 9: Arms
For the arms. I took a long piece of wood, cut it in half, and tapped it to the sides.
Step 10: Test It
The last step of the robot is to test it. Good luck and I hope this has helped you.
