Introduction: Robot Bumpers
Step 1: Gather Materials
For Materials you will need:
Cardboard
Wire
Metal Foil
Hot Glue Gun with glue
Scissors
Step 2: Cardboard
Get the cardboard and cut 6 pieces, 2 long pieces, 2 shorter pieces, and 2 pieces half the size of the shorter pieces. These 2 half size pieces will be glued to the back of the short pieces in order to elevate the bumpers allowing them to be further than the front of the wheels. Your method of attaching the bumpers like tape, glue, or velcro will be put on top of the half sized pieces.
Step 3: Cardboard "Springs"
In this step you will cut a piece of cardboard and split that piece into 2 thin pieces, then fold it and glue each one onto either side of the piece
Step 4: Metal Foil
Cut a square piece of metal foil the same size of the piece and glue it on the corners. Put glue on one of the thin strips' ends and attach it to the larger piece. Cut a second square and glue two of the corners over the end of the strip that's attached, now put glue on the other strip and glue it onto the piece then fold the foil over and glue it on. (If confused check pictures attached, its difficult to explain)
Step 5: Wires
Strip the ends of 2 wires and put one end of one wire into one piece of foil, then do the same for the other piece of foil.
