Introduction: Robot Made by 110 Led Bulbs
About: I am an growing expert of 15 years old and I am an Indian And my state is Tamil Nadu. One day the world will see me that is my dream I have both tinkercad and instructables account My user name on tinkercad i…
Hi friends today let's see about making a robot design using LEDs
LED means light emitting diode.
There are different colours of LEDs
You can see the finished robot in the picture.
I have used Arduino but you can use even batteries
I have used 110 led bulbs
According to your wish you can create big robot with more LEDs.
Step 1: Gather All
Gather all the supplies you need. I am using tinker cad. this project you can do in real also.
Note;if you are using Arduino means no problem. But if you are using battery means you need atleast 9 V battery.
Step 2: Use a Bread Board
In real it's easy to place the LEDs in an order but in tinkercad you need to use a bread board in order to place the LEDs in an neat order you need to use Bread board to place them and after placing remove the bread board.
Step 3: Divide the The Robot Into Different Segments
You shouldn't create the whole robot as a single one you need to create the head first then body then hands and finally legs.
Note; you shouldn't create the robot from bottom to top it's tough work.so you need to create the robot from top to bottom
Step 4: Connect the Parts With Jumper Wires
For connecting the LEDs use the jumper wires .
Please choose white colour jumper wire in tinkercad in order to show the robot alone if you want according to the colour of the LEDs
Note; don't use the colour which is different from the part of the robot.
Note; don't forget to use the resistor
Step 5: Code the Arduino
If you have the battery no need to program if you used Arduino , program it
First you need to show the pins which you have connected the LEDs.
Then make it Glow .
Step 6: If You Want to Copy My Code Copy the Below
void setup( )
pinMode ( 2 , OUTPUT) ;
pinMode ( 4 , OUTPUT) ;
pinMode ( 5 , OUTPUT) ;
pinMode ( 6 , OUTPUT) ;
void loop( )
digitalWrite ( 2 , HIGH) ;
digitalWrite ( 4 , HIGH) ;
digitalWrite ( 5 , HIGH) ;
digitalWrite ( 6 , HIGH) ;
delay ( 2000 ) ;
Step 7: Make Me Win
Please vote my project and make me win the make it Glow contest.
