Introduction: Make Your Night Light Rocket for Kids DIY
Does your kids love Space, Rockets and 3D printing? Then this tutorial how to make Night Light for kids DIY project is for you! Our Rocket Night Light is super easy to make. What we need for that? Almost nothing. We built a Rocket Night Light using seven grommets, eleven LEDs, can from beer (I think Dads will appreciate this part of project), and 3D printer.
What we like most of all in this project - it is our Rocket Night light doesn't require soldering at all!
Most time consuming part is 3D printing. To print seven parts of Rocket Night Light it takes about 7 hours. The rest is quite fast and easy. It takes about 15 minutes. Dads can make this project together with kids. You can have fun together. I would not allow children to cut foil, it can be a bit dangerous. The rest of project is absolutely safe and easy.
All STL files can be downloaded from our website: Catsonamission.com
Lets Get Started!
If you like our project and want to see more of what we get up for you please follow us on YouTube, Facebook, Instagram, and Twitter.
We would be happy to receive your likes on Youtube. It can help our young Channel.
- 7 grommets d2.5mm l=10mm
- 11 leds d=4.8mm of any color you like (we use blue)
- 1 can from beer (any brand you like)
- about 45 ramm of Filament for 3d printing (we used CoPET. Its is easy printable, strong and flexible enough)
- 2 battaries AAA
- 1 piece of sand paper
Step 1: Let:s Collect All We Need
Step 2: Step 1: Print Templates for Cutting the Aluminum Foil
- Lets print templates first. Then we will start printing the rest parts. And we will have time for scratching and cutting.
- We need to print two templates: face_rocket_template.stl and back_rocket_template.stl
Step 3: Prepare Aluminum Foil From a Can
Step 4: Cut "aluminum Wires" From Aluminum Foil
- Draw the wires with felt-tip pen.
- Then cut with scissors. Make contour of cutting a bit bigger. Late we will correct that.
Step 5: Print the Rest of the Rocket Night Light Parts
Step 6: Mount Our "custom Wires" and LEDs
- Lets mount our custom wires on to "rocket-middle" part.
- !!!IMPORTANT!!! It's important to avoid short soaking. Browse all tracks and cut it a bit if it is needed. Mount and check both sides.
- !!!IMPORTANT!!! Its important to observe polarity. Place all LEDs with long leg to bottom. Otherwise it will not light.
Step 7: Lets Mount Batteries - Night Light Almost Ready!
Step 8: Check
Step 9: Mount a Switch
- At first lets check. Did we placed a foil piece into upper part of switch? It's quite important. Otherwise the switch will not work.
- Put upper part of switch and fasten with a grommet
Hope your kids will enjoy it. Rocket Night light for kids seems to work!
Step 10: Test the Night Light Again
Step 11: Job Is Done
It looks we did it! We made our Rocket Night Light for kids!
Step 12: Enjoy
UPD.
We made one more Night light for kids:
You can shop it at https://amzn.to/2T3yx5A
That's it! Enjoy!
Thanks for watching!
Post your comments, suggestions, make likes.
Cheers!
Cats on a mission.
PS. All images are from website catsonamission.com. If you use it - please make backlink.
