Introduction: STYLISH SANDALS
Life of girls is incomplete without trendy sandals. and when your favorite sandals are worn out, its heartbreaking... so girls go and grab your favorite old sandals and some craft items and add little colors to your life by making these stylish colorful sandals.
Step 1: THINGS YOU REQUIRE...
Old sandals
OHP sheet
Skeins of different colors
Rubber solution
velvet Cloth
Needle and thread
Scissor
Glue
Craft gems
Step 2: PREPARATIONS
Remove the foam from the sole of the old sandals.
Step 3: MAKING OF THE BASE..
Keep the foam on the velvet cloth.
trace the outline on the cloth.
then draw slanting parallel lines on the outline.
Step 4: DESIGNING THE BASE...
Use chain stitch to embroider the lines with different colors.
i have used rainbow colors for this sandals.
repeat the steps for second sandal.
Step 5: MAKING OF THE BELT...
cover the old belts with white cloth.
then roll a white thread around it
Step 6: DECORATING...
Decorate the button as shown in the pictures.
And stick a craft gem in the middle.
Step 7: ASSEMBLING THE BASE..
Draw the outline of the foam on the OHP sheet.
cut it out leaving some space from the outline.
also cut the cloth same way.
Step 8: CONTD...
Stick the cloth to the foam of the sandal.
Step 9: CONTD..
Pass the belt through the OHP sheet and the foam.
then stick the OHP sheet at the back using glue gun.
Step 10: FIXING THE BELT...
fix the belt at the back of the foam and then cover the back of the foam with white cloth.
Step 11: ASSEMBLING THE SANDAL...
Stick the base to the sole using rubber solution
to stick it properly put some pressure on it and keep it overnight.
Step 12: FINAL LOOK..
and your all new sandals are ready...
Step 13: BEFORE AND AFTER...
