Introduction: Sandwich Bites
On this instructable I will show you how to make little sandwich bites easily from ingredients almost everyone already has. I kept mine simple for the demonstration. Oh and sorry in most of the pictures you can see the crack in my countertop I should fix that.
Step 1: Materials
The materials are easy but depend on who you are and what you like.
You need
- Bread
- Turkey or whatever you like
- I used cheese, again you don't have to
- Rolling pin(optional) You just need the bread to be flat
- A Butter knife you use this to spread any condiments you want and cut it later
Step 2:
Alright now to the making, you first roll the bread with the rolling pin down flat and then cut off the crust on all sides, or you could just push it down it isn't as sanitary though. You only need one slice of bread. I was doing two simultaneously.
Step 3:
Now you are going to start putting on everything you want. I would recommend you put on the mayo or anything spreadable you like first since that is the easiest. Then you put on your cheese since its already flat, and then anything else you want.
Step 4:
After you are done putting on everything you want you are going to take the bread and roll it what looks like a sushi roll and then cut it into three equal parts or as much as you want.
Step 5:
Once you are done you can enjoy your sandwich bites. I ate one before i took the picture... oops.
