Introduction: Savvy Cinnamon Rolls
These savvy cinnamon rolls will give glory to your taste buds. The rich surgery glaze is the perfect topping for these delicious bites of exploding flavored. Our reviews say that the cinnamon is scrumptious and the flavor is great. The perfect side is a nice hot cup of coffee with breakfast.
Step 1: Dough
Make the dough: Set aside 1/2 cup of flour. In a large bowl, toss the 2 and 1/4 cups flour, the sugar, salt, and yeast together until evenly dispersed. Set aside.
Step 2: Dough
Heat the water, milk, and butter together in the microwave until the butter is melted and the mixture is hot to touch. About 115°F (46°C). Stir the butter mixture into the flour mixture. Add the egg and only enough of the reserved flour to make a soft dough. I only needed 1/3 cup, but you may need the full 1/2 cup. Dough will be ready when it gently pulls away from the side of the bowl and has an elastic consistency.
Step 3: Dough
On a lightly floured surface, knead the dough for about 3-4 minutes. Place in a lightly greased bowl (I used non-stick spray) and let rest for about 10 minutes.
Step 4: Topping
Step 5: Filling
After 10 minutes, roll the dough out in a 14x8 inch rectangle. Spread the softened butter on top. Mix together the cinnamon and sugar and sprinkle it all over the dough. Add more cinnamon/sugar if desired. Roll up the dough tightly. Cut into 11-12 even pieces and place in a lightly greased 9-inch round pan. I used a pie dish, lightly sprayed with nonstick spray.
Step 6: Baking
Loosely cover the rolls with aluminum foil and allow to rise in a warm, draft-free place for 60-90 minutes. Here is what I do: heat the oven to 200°F (93°C). Turn oven off. Place rolls inside oven and allow to rise.
Step 7: Baking
After the rolls have doubled in size, preheat the oven to 375°F (190°C). Bake for 25-30 minutes until lightly browned. I covered the rolls with aluminum foil after 15 minutes to avoid heavy browning.
Step 8: Glaze
Right before serving, top your cinnamon rolls with glaze. Mix the confectioners' sugar, vanilla and 2 Tablespoons coffee together until smooth and drizzle over rolls. If it seems too thick, add 1 more Tablespoon coffee. You can replace the coffee with milk or cream instead, if you do not want a coffee flavored glaze. If you prefer a thicker glaze, add more confectioners' sugar and then add a pinch of salt to cut the sweetness, if desired.
Step 9: Glazing
Rolls are best enjoyed the same day, but stay fresh and soft in a covered container at room temperature or in the refrigerator for 5 days. Glaze the rolls immediately before serving. Rolls (with or without glaze) freeze well, up to about 3 months. Thaw in the refrigerator and heat up however you prefer.
Step 10: Serve!
This dough can be made the night before through step 4. Cover with plastic wrap and let rise in the refrigerator overnight. The next morning, remove from the refrigerator and allow to rise at room temperature, about 1 hour.
