Introduction: See Through Speaker
This speaker has a clear back, which allows the user to see through the back. The user can see all of the components inside of the speaker. The size of this speaker is 3" by 6.5" by 3".
Step 1: 3D Print Backing
This 3D print should be printed on the face with the holes for the speakers, down. This print, with a 10% triangle infill, should take about 14 hours on an Ender.
Step 2: Laser Cut the Clear Backing
Laser cut the clear backing with the file below.
Step 3: Connect Circuts
Use the picture, included above, to wire your speaker.
Step 4: Attach the Wiring to the Case
Glue the components to the inside wall of the speaker, as shown below.
Hot Glue should be used to secure the components to the wall.
Make sure that the glue gun is not kept close to the component for too long, to avoid heating the circuit.
Step 5: Attach the Backing
In these pictures, you can see how the backing is oriented.
The side with the female end of the plug is on the bottom along with the switch.
The green circles show where the plug and switch are in relation to each other. The mentions of top and bottom, are simply relational, to show how the backing should be inserted.
Step 6: PLAY YOUR SPEAKER
Plug the male end into the female end, and turn it off. This will allow your battery to charge. The light on the charging board should be red when you start charging and will turn blue when the battery is fully charged.
When you connect to the speaker via Bluetooth, it will show up as DW-CT14+. In settings, you can then customize the Bluetooth name of your speaker.
Congratulations! You have finished your Bluetooth speaker.
