Introduction: Sending Music Through a Frequency-Modulated (FM) Infrared (IR) LED
So why FM?
Well . . . that is a very good question. In highschool I attempted to transmit music through amplitude modulation with a cheap laser pointer and the noise was unbearable. Turns out that ambient light created a sort of feedback that made my project very inefficient. If the lights weren't out, the reciever wouldn't play my signal. Even with the lights out, only one song was audible--"Hey Soul Sister" by Train. So the purpose of this project was to fix that bug. We wanted to be able to send music in the middle of the day as clear as possible. With FM, we could set up a series of oscillations that would fix that. The circuit forms a free-running FM oscillator/modulator operating at twice the operating output frequency. This is the core of the modulator. The output is linear ramping voltage of either positive or negative slope.
And why an IR LED?
We originally planned to use a laser pointer and a photodiode. However, it turned out that we bought the wrong photodiode--we had a blue photodiode receiving red laser light. We realized this at the very last minute and had to change to parts we already had--an IR phototransistor paired with an IR LED. If you want to use a laser pointer and a correct photodiode, you can simply replace these components.
Either way, this was the Intro and I hope you will enjoy building this project. It's a bit challenging but I will try to make it as simple as possible.
Step 1: Parts List for Modulator/Transmitter
For the transmitter:
Capacitors
.1uF ………………………….5
4.7uF (25V)………………2
270pF……………………….1
1uF (35v) ………..……….2
.001uF………………….…..1
.01uF…………………….….1
10uF (25v)…………………1
100uF (16v)………………1
Diodes
1N5817 (Schottky rectifier)……….2
IR LED………………………………………….1
1N914…………………………………………1
Resistors
10k…………………………………………….5
2.7M……………………………………….…1
270k…………………………………………..2
100k…………………………………………..4
2.2k………………………………..………….1
33k…………………………………………….1
560 Ohm………………………………..….1
240 Ohm……………………………….…..1
2 Ohm………………………………………..1
ICs
LF347 (Quad JFET op-amp)……………………1
CD4069 (Hex CMOS inverter)………………………..1
CD4013 (Dual CMOS D flip-flop)…………………….1
TC1411 (HS driver)(Digikey TC1411CPA)………..1
LM317 (Voltage regulator)…………………….……..1
Potentiometers (trimmers)
100k (trimpot)……………………….…..1
10k (trimpot)………………………….…..1
500 Ohm (trimpot)……………………..1
you also need a Breadboard and many connectors/wires
I suggest you purchase the ICs through Digikey.com, The Pots and diodes through Radioshack, and the rest through Jameco. Doing this, my modulater cost me about $45-60. I bought most parts in exccess. I suggest Part no. 20812 for breadboard. You can also use a regular breadboard if you wish to work under a budget.
Step 2: Parts List for Demodulator/Receiver
Capacitors
.1uF………………………….......................7
100uF (16v electrolytic)………………….1
220pF (mica or metallized film)……..1
2200pF (mica or metallized film).….1
.001uF (2% polypropylene)…………..1
.01uF (metallized film)……………………2
.001uF (metallized film)………………….2
.05uF (ceramic)…………………………..….1
270uF (16v electrolytic)………………….1
1uF (35v)………………………………….…….1
Diodes
IR Phototransistor………..1
1N914………………………….1
Inductor/choke
4.7 mH (molded choke)…………….1
Transistor
2N2222…………………………..1
Resistors
1k………………………1
470 Ohm…………..1
2.2k……………..…..1
820k………………….1
33k…………………..4
100k……………………..4
9.53k……………………..1
10k ………………….…...5
39k………………….…….1
10 Ohm…………….…..1
3.3k............................1
ICs
LF347 (Quad JFET op-amp)…………………………1
CD4069 (Hex CMOS inverter)…………….………1
CD4013 (Dual CMOS D flip-flop)…………………1
LM386-4 (Audio amp.)………………..……………..1
Potentiometer (trimpot)
10k (Trimmer)…………………………………………….1
Breadboard and wires/connectors
Step 3: Building the Modulator Part 1 (m1)
Basically, m1 is just the modulator. U2 pins 7,11,13 are grounded and pin 14 goes to VDD as well. U3 pins 4,6,7,8,9,10, and 11 are grounded while pin 14 goes to VDD. U4 pins 4 and 5 are grounded. no VDD for U4, it operates through oscillating signal.
In case needed:
U1 is the LF347
U2 is CD4069
U3 is CD4013
U4 is TC1411
U5 is LM317
Step 4: M2 the Diode Current Regulator
Step 5: M3 the Line Amplification
Step 6: The Modulator
Step 7: The Demodulator (d1)/Receiver
I have also uploaded the schematics.
In case needed:
U1 is LF347 (pin 4 to VDD and ground pin 11)
U2 is CD4069B (Pin 14 to VDD and Ground pins 7,9,11,13)
U3 is CD4013B (Pin 14 to VDD and Ground pins 6,7,8,9,10, and 11)
U4 is LM386 (Pin 6 to VDD and Ground pin 4,2)
This first section is the Bandpass Amplifier
Step 8: D2 the Limiter
Step 9: D3 the Integrator
Step 10: D4 the Audio Output and Bias
Step 11: Linearization
1. Remove Ipod (or other audio input) and speaker.
2. Remove LED and Phototransistor.
3. Connect the pins where the positive and negative leads of the LED would be placed together via a 100 ohm resistor
4. Connect this via 10M ohms resistor to the pin where the phototransistor would connect to the 220pf capacitor.
5. Connect the Modulator's Grnd to the Demodulator's Grnd.
6. Power the boards.
7. Configure the 100K pot on the Modulator and the 10k pot on the Demodulator until you hear something.
8. Replace components.
Now you can have fun with your FM IR Transceiver!
Here is a short video of mine working.
The noise in this transmission is actually the speaker. I waited till last minute and had no other choice but to use a broken speaker from a previous lab project--hence the noise and need for an amplification tool (i made a paper megaphone). A new speaker would make the quality many times better.
So there you have it. You may be required to be a member of this website to be able to construct this project with my guide; this was the only way I could upload the schematics from Multisim. Hopefully yours goes as well as mine. Have Fun!
