Introduction: Arduino Serial Monitor Challenges
Wanna test your Arduino programming skills?
Here are six challenges each of which is harder than the previous one and requires you to use more and more of the Serial Monitor functionality. All in all this is a fun way to practice your arduino programming with no circuitry needed, just plug in your Arduino and you are ready to go!
Step 1: Simple Counter
This is a program that counts from 1 onwards and prints out each number on the serial monitor.
Step 2: Countdown Timer
This is a program that counts down from a desired number and prints out “Countdown Complete” when the countdown reaches zero!
Step 3: Digital Clock
This is a program that imitates a standard clock presenting time in the same format as seen on most digital watches
Step 4: Test Even or Odd
This is a program that reads a number put in by the user and then tests whether the number entered is even or odd
Step 5: Prime Number Tester
This is a program that reads a number put in by the user and then tests whether the number entered is a prime number
Step 6: Factorisation Program
This is a program that reads a number put in by the user and then tests whether the number entered is a prime number. If the number is NOT prime the program will list all the factors of this number.
Step 7: Reversing a Number
This program takes in a real number as in input through the serial, then it prints out the same number with the digits reversed.
