Introduction: Servo Controlled Prosthetic Hand
Hi, here I am making a prosthetic hand controlled by servos to make it grip. I am making a right hand but I included the files to print a left palm as well. The assembly is the same for both left and right hands.
Step 1: Printing the Parts
- Download the stl files attached to print out the parts of the hand.
- The parts you will need are:
- 1 Wrist
- 1 Right Palm OR Left Palm
- 2 Wrist Pins
- 2 Wrist Pin Caps
- 5 Fingertips
- 5 Finger Pins
- 5 Proximals
- 2 Knuckle Pins
- 1 Thumb Pin
- 1 Servo Mount
- Make sure to shave off any supports or any excess plastic.
Step 2: Assembly of the Hand
- If your pin is not going in, try:
- Pinch the two prongs of the pins to make them smaller to go through the whole.
- Use a small mallet to force the pins in.
- Shave any pins or holes down with a file so they fit more easily.
Step 3: Stringing the Hand
- You will now string the hand with two things: elastic and fishing wire.
- In my pictures, the fishing wire is the greenish color and the elastic is black.
- The fishing wire is used to pull the fingers so it needs to be strong.
- Elastic should be a rope like elastic no more than 1.5 mm in diameter.
- First string the elastic:
- Cut 5 pieces of small elastic rope measuring from the tip of the finger to the bottom of the palm
- Tie one end on the little bar on the top of the finger closest to the tip.
- Thread it under the other bar, through the small hole on the proximal, and through its respective channel on the top of the palm.
- Tie it around its respective hole on the bottom of the palm and cut off any excess.
- Next string the fishing wire:
- Cut 5 pieces of fishing wire measuring from the tip of the finger to the bottom of the palm.
- Tie one end on the bar near the tip of the finger on the BOTTOM of the finger.
- Thread it through the channel on the bottom of the finger.
- Next, thread it through the hole so it comes out on the top of the palm.
- Thread it through its respective channel on the palm with the elastic from the same finger.
- Thread it through the hole where the elastic is tied but DO NOT tie it around the hole.
- Just leave the fishing line laying there for now.
Step 4: Setting Up the Arduino Board
Follow the pictures very meticulously on where to put the pins, and then plug the Arduino board into a computer.
Here are some details:
- I use PIN 3 for the push button
- I use PIN 9 for servo 1
- I use PIN 10 for servo 2
- I use a 10k resistor for the pushbutton
I am using 2 standard 180 servos.
Step 5: Coding the Servos
Basically, what the code does is telling the servos that when I push the button the servos will go to a set position and stay there until I release on the pushbutton. When that happens the code tells them to go back to their original spot and stay there until the pushbutton is pushed again.
- I have servo 1 going to PIN 9 and servo 2 going to PIN 10.
- I have the pushbutton going to PIN 3.
Here is the code:
#include
int pos = 0;
Servo servo1;
Servo servo2;
void setup() {
pinMode(3, INPUT);
servo1.attach(9);
servo2.attach(10);
void loop() {
while (digitalRead(3) == HIGH ) {
servo1.write(440);
servo2.write(172);
while (digitalRead(3) == LOW ) {
servo1.write(0);
servo2.write(15);
Step 6: Mounting the Servos
- Slide the clip on the bottom of the mount into the channel on the wrist.
- You can shave the clip down with a file if it is too big.
- You can also hot glue the clip into the channel in so it does not slide around.
- Slide both servos in the mount:
- Make sure they are upside down.
- Make sure the arm of the servo is closest to the palm.
- Make sure the servos are sitting in the mount, but are far away enough from each other so the arms don't collide.
- Hot glue the servos in place so they don't move.
- Tie 3 loose fishing line ends to one to the hole on the end of the servo arm.
- Tie the other 2 loose ends on the hole on the end of the other servo arm.
Step 7: Padding
I did not use padding or straps because my hand was not going to be put to use.
If you wish to put on padding and straps, here's a link to a video explaining how to do it:
- Materials: https://www.youtube.com/watch?v=ql7Uy_WDKyo&t=0s&index=14&list=PLA7_By5ei42zmZThuTbNQOQCmkE4qloEA
- Padding: https://www.youtube.com/watch?v=_FftDYzVe2o&index=14&list=PLA7_By5ei42zmZThuTbNQOQCmkE4qloEA
- Straps (part 1): https://www.youtube.com/watch?v=JhAWUqAqRVE&list=PLA7_By5ei42zmZThuTbNQOQCmkE4qloEA&index=15
- Straps (parts 2): https://www.youtube.com/watch?v=yPLFowuJZoE&list=PLA7_By5ei42zmZThuTbNQOQCmkE4qloEA&index=16
Step 8: Using You Prosthetic Hand
- To grip the hand push the push button and hold until you wish to release. When you stop pressing the push button the hand will stop gripping.
- Feel free to ask me any questions about the hand.
- Enjoy!!
