Introduction: Set Up an Electronics Cum Hobbyist Workstation
This instructable will guide you through the process of setting up your own workspace.
Step 1: THE BARE MINIMUM
Everyone who is interested in becoming a hobbyist must be in possession of these elements before getting started :
1) A personal space
2) A table and a chair you are comfortable with
3) A good source of lighting
4) A wall outlet with support for at the least 10* Amperes of electric current
5) A spike guard with at the least 4* outlets ( Preferably one with independent switches )
6) A scientific calculator
* Indicates values that can be altered according to user's preference and needs.
Step 2: THE ESSENTIAL POWER TOOLS
1) A soldering station
i) A soldering iron
ii) A soldering bit
iii) A soldering stand
iv) Solder
v) Soldering flux
vi) Wick
vii) A tip cleaner
viii) A pair of tweezers
ix) A pair of wire strippers
x) A pair of nippers
xi) An anti ESD ( Electro Static Discharge) strap
xii) A PCB holder
xiii) An anti ESD cum heatproof mat
xiv) A pair of anti ESD gloves
xv) Heat shrink tubes
2) A hot glue gun
3) A drilling machine and accessories
4) A hot air blower station
5) A rotary tool and accessories
Step 3: THE ESSENTIAL MEASURING TOOLS
1) A digital weighing scale
2) A ruler
3) A multimeter
4) A digital Vernier caliper
5) A clamp meter
6) A tape measure
7) A spirit level
8) A right angle set square
Step 4: THE ESSENTIAL CUTTING AND FINISHING TOOLS
1) A precision knife
2) A pair of scissors
3) A pair of nose pliers
4) A set of files
5) A set of drill bits
Step 5: THE ESSENTIAL FASTENING TOOLS
1) A set of Allen keys
2) A precision screwdriver set
3) Assorted screwdrivers
4) An adjustable wrench
5) A hammer
6) A mallet
7) A magnetic screw tray
Step 6: THE ESSENTIAL ADHESIVES AND FASTENERS
1) Nuts
2) Bolts
3) Spacers and stand offs
4) Washers
5) Velcro
6) Zip ties
7) Rubber bands
8) Hot glue sticks
9) General glue
10) Super glue
11) Electrical tape
12) Double sided tape
13) Packing tape
Step 7: THE ESSENTIAL BUILDING MATERIALS
1) ZERO PCBs
2) Project enclosures
3) Acrylic sheets
4) Foam sheets
5) Corrugated cardboard sheets
6) Sun board
Step 8: THE ESSENTIAL POWER PACK
1) A variable benchtop power supply with at the least 12* volts and 10* Amps
2) Batteries for your applications
3) Chargers
4) A breadboard power supply module
Step 9: THE ESSENTIAL ELECTRONIC COMPONENTS
1) Microprocessors :
- Arduino UNO
- Arduino MEGA
- Arduino Nano
- Arduino Pro Mini
2) Assorted breadboards
3) Berg strips ( Male and Female)
4) Assorted jumper cables
5) PVC ( Poly Vinyl Chloride ) wires
6) Single core wires
7) Alligator clips
8) Power connectors
9) Interface connectors
10) Push button switches
11) Toggle switches
12) Relays
13) Buck converter
14) Boost converter
15) Potentiometers
16) Buzzers and speakers
17) Audio amplifier ICs ( Integrated Circuit )
18) A radio transmitter
19) A radio receiver
20) Assorted resistors
21) Assorted electrolytic and ceramic capacitors
22) Assorted transistors
23) Diodes
24) Assorted ICs and sockets
25) Assorted LEDs ( Light Emitting Diodes )
26) Seven segment LED display
27) LCD ( Liquid Crystal Display ) module
28) Servo motors
29) Plastic geared motors
30) BLDC ( Brushless DC ) motors
31) Stepper motors
32) ESCs( Electronic Speed Controller ) for BLDC motors
33) L293d motor driver
34) A4988 motor driver
35) HC05 Bluetooth module
36) Assorted sensors :
- HC-SR04 ultrasonic sensor ( Proximity sensor)
- LDR ( Light Dependent Resistor ) module ( Light sensor)
- Microphone module ( Audio sensor )
- HC-SR505 PIR ( Passive Infrared) sensor ( Motion sensor)
- DHT22 module ( Humidity and temperature sensor)
- ADXL345 module ( Orientation sensor )
- Water level sensor
- Force sensor
- TCS3200 module ( Color sensor )
- MQ135 air quality sensor
Step 10: MISCELLANEOUS
If you are interested in documenting and publishing your work then these will be a good addition to your arsenal :
1) A digital camera and/or videocam and accessories
2) Camera flashes and accessories
3) A microphone to plug into your camera
4) A decent full sized tripod
5) Digital storage devices and accessories
6) A Personal Computer
Step 11: ADVANCED TOOLS
You may find yourself using these tools once you have made progress in your hobby :
1) A 3-D printer
2) A CNC ( Computerized Numerical Control ) cutting machine
3) A signal generator
4) An oscilloscope
Step 12: GO SET UP YOUR DREAM WORKSTATION NOW!
Categorize and organize your tools, parts and components neatly and have fun making stuff. :D
Consider following me on my instagram page to never miss an update :
