Introduction: Shellfish Fideuà
About: I'm currently studying Coastal Engineering, I'm crazy for miniatures and dioramas, and I see a opportunity of improvement in every broken thing.
This recipe was created in the town of Gandía when two fishermen were preparing a Paella, but they decided to add nooddles as they had run out of rice. It turned out to be so tasty that it became a famous recipe in Spain.
Step 1: Ingredients
For two people:
200g Fideuà noodles
400-500ml Fish Soup
4 Scarlet Shrimps
4 Mussels
200g Monkfish (not in this recipe because I think it's too much food, but the original recipe includes it)
1/2 Onion
2Tbsp Tomato Sauce
1Tbsp Sweet Paprika
1 Clove of Garlic
Saffron or Yellow Coloring
Salt
Step 2: Making the Fish Broth
You can buy the fish broth at a supermarket or make it at home. The ingredients are cabbage, leek, carrot, celery, potato, fish head or/and fishbone or/and fish skin.
- First wash the vegetables and different fish parts.
- Add water till it covers all the ingredients, add some salt and cook it for 15-20 minutes if the taste of the fish you chose is strong, and up to 2 hours if its taste is soft.
- As soon as froth appears on the surface, remove it because otherwise it will give the broth a bad taste.
- Keep 400-500ml in the fridge. You can freeze the rest for another recipe.
Step 3: Frying the Mussels and Shrimps
- Fry them in a pan using some olive oil.
- Once the mussels open and the shirmps are a bit toasted, remove them from the pan.
- Remove any antenna or byssus threads from the olive oil.
- If you want to add monkfish, cut it in dices and fry it in this same pan.
Step 4: Making the Fideuà
- In that same used oil, fry at low heat the half oinon along with the garlic clove and a tbsp sweet paprika. I always add some water to make the onion softer.
- Once the onion is cooked (15-20 minutes), add the noodles, tomato sauce and a pinch of saffron. Mix it all and then add the fish broth and bring it to boil.
- While you cook the noodles, remove the head and legs from the shrimp and one of the shells of the mussel.
- When the fish broth has reduced to half its volume, put the shrimps and mussels on top of the noodles so that they could release their juices.
- When you see there is no fish broth on the surface, turn the fire off and let it settle for 3 minutes.
Step 5: Presentation Suggestion
