Introduction: Shooting Gun Rest
my Fellow Instructables. Why Go and buy a New Gun Rest? $300 $500 Dollars?
I Decided To Make One. total Cost $40 Dollars
Im Using Metal Tubing 2/3.4 inches by 1 And 28 inches Long.
Step 1: The Build Up
i Used a 28 inch long Rectangle pc of metal tubing for the body. On one end i welded a 4 inch pc Going up.
This is the Back support and i also welded two triangle Pcs For extra strength
On the bottom of the back support i pt a 1 inch long nut and a long Bolt to adjust the Back Up and Down
The Front has another Pc 5 inches Tall and two one inch long Nuts to hold the screw that makes the top move
Up And Down.
i welded a small triangle on the bottom of the front Pc For extra support.
And a 4 inch long plate that supports the Front of the gun.
But after making it it moved way to much so i changed the design
Step 2: Front Support
Found a door hinge and this worked perfect No more movement.
by moving the screw the plate moves Up And Down notice the stained wood that will hold the Foam.
Step 3: Foam Support
This foam came from a foam mat.
using my band saw cut the Pcs for the front and back supports
Step 4: Paint...
last step Some Matt green Paint
and she is Done.
Step 5: Tools and Materials.
Rectangular Metal Tubing 40 inches long by 2 3/4 and 1 inch
3mm thick metal for the Legs and top base.
3 1 " long Nuts and Two 5 " Bolts
Foam.
Ribbets, Ribbet Gun,
Rubber,
Grinder,Bech grinder,
Band Saw
Safety Gear. glasses,Boots , Gloves,Ear muffs
Welding Machine.
Paint Respirator,
Now Go And Make Something.
Step 6: Front Legs
Made a Cardboard template and then Cut the Legs out of metal. Two of them.
we;red the legs to the Body and place a bottom base on the legs
