Introduction: Silver Cleaning and Polishing With Natural Ingredients
Learn how to polish your silver without the use of harsh chemicals. This guide will show you an easy and cost-effective method using common household items for a shiny and eco-friendly finish.
  • tarnished silver
  • container
  • aluminum foil
  • baking soda
  • spoon
  • hot water
Step 1: Boil Water
Boil enough water, so that the tarnished silver will be fully covered in the container.
Step 2: Wrap the Container With Aluminum Foil
While the water is boiling, wrap the exterior of the container with aluminum foil. Ensure that the entire outer surface is covered.
Step 3: Prepare the Cleaning Solution:
Until the water is boiled, add baking soda to the container. Use a couple of tablespoons, but adjust for heavily tarnished silver or larger containers.
Step 4: Submerge Silver Items:
Place the tarnished silver items in the container. Pour the boiling water into the container, ensuring the silver items are fully immersed in the hot water and baking soda mixture. The combination of aluminum, hot water, and baking soda will work synergistically to remove tarnish from the silver.
Step 5: Let It Work
Let the silver soak in the solution. The time needed to remove tarnish depends on its severity. If the water cools during the process, add more boiling water to maintain the effectiveness of the cleaning solution.
Step 6: Conclusion
Enjoy your sparkling silver without the use of harsh chemicals. This natural cleaning method is not only effective but also environmentally friendly and cost-efficient.
