Introduction: Silver Medal
Step 1: Tracing
Trace a circular object three times onto cardboard.
Step 2: Cut
Cut out the three circles with a box cutter.
Step 3: Glue Together
Hot glue the three circles together.
Step 4: Drill
Drill small hole through the circle, near the top.
Step 5: Tape
Use masking tape to tape over the entire circle. Then cut triangles one edge. Fold every other triangle and cut the other triangle off.
Step 6: Paint and Drill
Paint the circle with silver metallic paint. Then drill again over the hole you drilled earlier.
Step 7: Ribbon and Binder Ring
Get a binder ring and put it through the hole. Then take the ribbon and lace it through the binder ring. Tie a knot to connect the two ends of the ribbon.
Step 8: Deccorations
Write what you want on the medal with a Sharpie.
