Introduction: Simple & Easy Dimmer Circuit Using 555 IC for LED Strip Lights
About: For more content please subscribe to my YouTube channel @ https://goo.gl/BHxFf7
In this tutorial i will show you how to build a dimmer for the LED Strip Lights using 555 IC.
To build your own Dimmer Circuit using 555 IC you can watch the video embedded in this step or continue reading
Step 1: Parts List
***Parts List***
1. 555
2. 0.1uF Ceramic Capacitor - 2
3. 1N4007 - 2
4. 8 Pin IC Holder
5. 47k Ohm Pot
6. Resistor (1k & 120 Ohm)
7. BC547
8. PCB & wires
***Purchase or Affiliate Links***
Banggood
1. LED Strip Light - https://goo.gl/sCdDTX
2. 555 IC - https://goo.gl/eePxAN
3. Pot Knob - https://goo.gl/eZRT9L
AliExpress
1. LED Strip Light - https://goo.gl/1jgvRF
2. 555 IC - https://goo.gl/sb37S5
3. Pot Knob - https://goo.gl/MVeCHH
Amazon USA
1. LED Strip Light - http://amzn.to/2eVDY2J
2. 555 IC - http://amzn.to/2vgxMcD
3 .Pot Knob - http://amzn.to/2h2F5hN
Amazon IND
1. LED Strip Light - http://amzn.to/2vSfYkV
2. 555 IC - http://amzn.to/2uHPjc4
Note: all the purchase links provided are affiliate links
Step 2: Circuit Diagram
Construct the circuit diagram as shown in the circuit diagram. The circuit should be powered above 10 volts & the voltage should not exceed more then 14 volts. To control the brightness you can use the pot.
