Introduction: Simple Easy to Make Bow
About: My goal is to show you how to make random stuff with items almost EVERYONE HAS! Even your pet can do it....maybe!
Step 1: Supplies
All you'll need is duck tape, a rubber band, and a stick
Step 2: Finding the Stick
You need to find a bow shaped stick. Bamboo works perfectly also. I found a stick with a small stub on the side to balance the arrow. For the arrows you can just use sticks or use the homemade arrow instruct able that I will make soon
Step 3: Building
Just cut the rubber band, put one end each of the rubber band on each side of the stick. Cover with duck tape and press duck tape down. The reason I did not use hot glue is so if your rubber band breaks you can just take off the ducktape, add a new rubber band, and re place the duck tape down! THIS IS THE FIRST AND ORIGINAL. IF YOU SEE THIS ANYWHERE ELSE, IT IS A COPY!!!
