Introduction: Simple Hydroponic System
Grow your own fresh food in less than a month and for under $10 with this system. It is quiet and takes little maintenance. Much cheaper than store bought alternatives too. This system works well for plants that are fast to germinate such as leafy greens and herbs.
Step 1: Parts
Storage Bin - about $10 for one
http://www.walmart.com/ip/Sterilite-41-Quart-Stora...
Grow Light - about $10
http://www.walmart.com/ip/Good-Earth-Lighting-Inc-...
2" Garden Cups - $0.30 each (sourced locally)
http://www.amazon.com/Inch-Round-Orchid-Hydroponics-Slotted/dp/B0058PB574/ref=pd_sim_lg_11
Rock Wool - 8$ per 24 (sourced locally)
http://www.amazon.com/Grodan-Rockwool-Cubes-Inches...
Water Pump - about 15-20$ (all about preference)
http://www.amazon.com/Watts-Jebao-Submersible-Foun...
Vinyl Tubing - $4 (0.50$ per foot)
Home Depot/Lowes
Zip Ties - cheap
Home Depot/Lowes/Ace/Online/Anywhere
Plant Nutirents - 14$
http://www.amazon.com/UltraGrow-Liquid-Nutrient-Se...
Home Depot/Lowes
Zip Ties - cheap
Step 2: Construction
Cut holes that are approx. 5" apart from each other. A Dremel tool works well for this or a sharp box cutter or a hole bit and drill. The size of the holes depend on the size of your pot you will be using for each of the seeders. A space should be let on one side of the top to keep the pump to be away from the roots.
Using 1/2" inner diameter tubing, about 8' was planned to wrap around the holes and then secured in place with zip ties. A small drill bit was used to make the holes for the zip ties. On the side of the tube facing the hole for the pot, a small hole was drilled so water would shoot at the bottom of the pot.
A slight rim of hot glue was built upon the edge of the container to eliminate any leakage.
The tubing was fitted into the output of the water pump sealed with hot glue**. The end of the tube was also plugged with hot glue.
Disclaimer.. Hot glue is an amazing invention and can be used to fix anything as it is extremely stong. Some sources say it was used to build the Eiffel Tower.
The lighting system was not fully designed. It is largely a matter of preference and available tools. The lights should be adjustable.
Step 3: Planting
The rock wool blocks were cut into semi conical shapes that would fit into the pots. A standard scissor works well. Don't breathe in rock wool shavings!
Liquid plant nutrients were also added to speed up the growth rate. Using a siphon and removing a gallon of water and then replacing the gallon of water with one with nutrients added should be done every other week. It does take some preference and experimenting to determine what works best for you.
Small cups were placed on top to keep the humidity levels high.
Seeds were placed in the main hole and then in two other holes made by pencils in the rock wool. About 5 seeds went into each hole.
Step 4: Growth
This is after 7 days of growth in a room averaging 61 oF with 16 hours of artificial light.
Seen growing is spinach, arugula, basil, chives, and lettuce. These plants have the fastest maturity rate.
Step 5: Enginerding Thoughts
Flow rate?
The flow rate out of the first hole isn't a noticeable difference compared to the last hole. Thanks to a short tube, a low overall flow rate and minimal frictional loss.
Cost Effective?
Neglecting the initial cost, the pump power, lights and nutrients are what matter over time. The 2 lights are 17 watts each, the pump is about 5 watts and the nutrients 15$. Assuming the lights are on for 16 hours a day for 45 day and the pump is continuously running while the cost of electricity is $0.10/kWh....math...The electricity cost alone is about $2.65 and maybe 1/2 a bottle of nutrients which is $7.50. So about $10 for a full 15 pots of food!
I would say yes!
Enjoy!
Cost Effective?
I would say yes!
Enjoy!
