Simple T Track for Woodwork Jigs
80K33956
Intro: Simple T Track for Woodwork Jigs
I started to make a new small cross cut sled for my table saw the other day and decided to make the t slot directly in the fence rather than buying an aluminium one,
with that in mind I decided to write this little article to show people just how easy they are to make. this method can be used to make slots in jigs or to make a track to install in a jig.
Materials:-
  • A piece of wood suitable for making the fence or track ( hardwood is best )
  • 1 nut and bolt sized for the application ( for my example I have used 8 mm )
Tools:-
  • A table saw or Router (optional used as an alternative for cutting the slots)
  • Good quality wood glue
  • Clamps
STEP 1: SELECTING MATERIALS
Firstly we need a suitable piece of wood for the project I would suggest using a hardwood for this as it will last longer, an 8 mm bolt mine is around 40 mm long and a 8 mm nut,
I have then used the table saw to remove around 20 mm from the top of the piece of wood as seen in the picture below.
STEP 2: SETTING THE DEPTH OF CUT
First we need to set the depth on the blade this needs to be just a little deeper than the head of the bolt.
STEP 3: CUTTING SLOTS
With the depth set move the fence so the blade is more or less center of the wood, it does not have to be perfect just close.
Run the wood through the saw and at the end of the cut turn the wood around so the opposite face is against the fence and run through the saw again, this method will center the groove on the work piece.
With the first cut complete adjust your fence so you make the slot a little wider and once more run the wood through the saw, as before flip your work piece at the end of the first cut and run through again, repeat this process until the slot is just a fraction wider than the head of the bolt. ( Remember because we are cutting twice for each fence adjustment it will double the amount removed so be careful towards the end of the process).
With the first part cut we now turn our attention to the smaller section we removed at the start,
This time we need to set the depth on the saw to around 4 – 5 mm and once again set the fence so the work piece is roughly center on the blade. As before we do two passes through the saw for each adjustment until the slot is slightly wider than the threads on the bolt.
STEP 4: FORMING THE JOINT
We now have both of the slots cut so we now need to join the top to the bottom using a good quality wood glue, spread the glue sparingly as we don’t want any excess in the slot.
(Spread the glue on the smaller faces of the bottom piece rather than the top).
Remember to wipe off the excess glue with a damp cloth and leave to dry for several hours.
STEP 5: REMOVING THE WASTE
After allowing the glue to dry remove the piece from the clamps and head back to the table saw.
This time we need to set the fence so the blade just cuts through the top most part of the slot as in the picture
Run the timber through the saw and you should be left with a T slot
STEP 6: NOT FORGETTING THE NUT
We are going to need something to tighten the jigs, this could be just using the nut and a washer or you could make something like this out of a little bit of scrap.
49 Comments
Looks a great idea, at least for you lucky guys in the US where timber is plentiful and cheap, but here in UK, for the cost of a piece of decent hardwood, you might as well buy a lenght of aluminium T-track from Ebay, the cost would be around the same, and you'd save time and hassle...
Do you not have used PALLETS in the United Kingdom?
We do this was made from a piece of pallet wood
Hardwood is not cheap in the U.S.
When making a crosscut guide, with or without a t-slot you will be using a piece of wood anyway. The t-track only adds to the cost.
Thank you for the comment this was made from a piece of hardwood taken from a pallet so no cost except a little time.
Sadly I also do not live in the US, I live in Derbyshire UK and I agree the prices for decent hardwood in the UK are ridiculous.
I use mainly recycled timber for my projects
Why wouldn't you just glue two small pieces of wood to the top on track
instead of wasting the time and material routing out, gluing up, and
then cutting off the bigger piece you used?
The method in the instructable will result in a more accurate slot as well as a more easily aligned, glued and clamped slot cover. Nicely done.
That is absolutely not true. You can precisely measure and cut two thin strips of hard wood and glue them to the base -- I like the instructable but disagree with the wasted effort and material to glue the top part -- so make it any way you want and I'll make it my way.
That is the way I make mine & they turn out just fine.
"so make it any way you want and I'll make it my way." " of wasting the time and material"
Just a 'heads up' that your first comment about his effort "wasting time" was unnecessarily rude as he was showing 'one way' and made no pretenses that it was 'the' way.
If you look through the more polite comments, you may see that one or more readers also shared alternative approaches to this objective without adding 'negative connotations' in the process.
If one follows Instructables for any length of time, one discovers the truth in that old saw about skinning cats.
you try fiddle with small pieces of wood, i will finish way before you and will look neater and be way more accurate than your tooth pick method... router, clue, cut... you have to hold small strips, try to clamp... and just dont say nail because we dont all have nail guns...
I agree with author, this method seems easier and really not much more material wasted compared to cutting two tiny strips. I imagine the piece that was cut away would likely be reused for something else.
As someone that has been a professional woodworker for the last 40 years I am offering some sound advise as to how a wood shop would handle this build. The time to route the top piece and the waste of material would NOT be an acceptable method for doing this build -- time and material equals money -- and in business we are not in the habit of losing either. Again having said that everyone here is welcome to do it your way and I'll do it mine. It's a nice instructable other than that.
you are correct you could just glue two pieces on top as you suggest and I have done that on a previous one where I added the slot to an existing fence.
I just find this way easier for me to line everything up
This is great. I'd often scratched my head on this one!
Just a thought that might make it easier by reducing machining…
As it stands there's a wide groove for the bolt head in the lower piece, and a narrow groove for the shaft in the upper piece.
How about machining the wide groove and the narrow groove both in the top piece?
Also sand to a fine finish and lots of silicone spray!
Well done that man.
My thought exactly, use a "T" bit in a router. Then again if you don't have one this two piece two piece process is the most accurate and simplest way to make them.
Good catch!
Or, one could spend 9.99 and get " Yakamoz 1/4" Shank T-Slot Router Bit T-Track Slotting Carbide Wood Milling Cutter. $9.99" off Amazon
I did it. Made 2 1/2 so far. (The third one is in the clamps now). Each one better than the previous.
More Comments
