Introduction: Simple Under-Laptop Box Fan
Have you ever wanted a small fan to blow on you. well all it takes is a few simple materials and you can stay cooler, without taking up your entire desk.
STUFF YOU WILL NEED
1. A box that desires your wish for space to fan ratio
2. Some scissors
3. Computer fan(s)
4. A power adapter
5. Electrical tape
6. Duct tape
7. Switch (Optional)
8. Wire strippers
Here is a vid
Step 1: Choose Choose a Box and Cut It Out
find a box that fits everything you want and need. Cut out breathing holes for the fans, and put a slit down the sides, make a "lip" shown below. this angles the air flow, so adjust to your comport.
Step 2: Duct Tape Is Your Friend
secure the fans in but duct taping them to walls, make sure there is no tape in the area were the blades spin, it will make a annoying noise.
Step 3: The Wiring
This part is very simple to someone who knows wiring. if you dont that ok i have made a diagram for you
IMPORTANT!
FOR A POWER ADAPTER YOU CHOOSE MAKE SURE IT IS THE AMPERAGE IS THE SAME AS THE FANS, THE MORE FANS YOU HAVE THE MORE TIMES YOU MUST SPLIT THE AMPS YOU HAVE
for example:
Below i have a picture of my adapter, my fans require 12v and .13 amps, so my adapter is 12v and 500mah which is .5 amps so each fan takes .13 amps, you must meet this number, or be below the adapters so it draws .26 amps out of .5. DO NOT GO OVER THE ADAPTERS AMPS!. make sure the volts is equal to the fans, this number does not need to be divided.
Step 4: Seal the Box
duct tape all flaps so the air cant escape
Step 5: Enjoy
enjoy your simple but effective cardboard box fan!!!
