Introduction: Simple and Easy Bird House
The title says it all ¯\_(ツ)_/¯
- Half a log of wood about 7 inches tall, does not need to be exact
- Wood glue
- Bandsaw
-Drill
- 1/8 inch bit
- 1.25 inch bit
- Rope
- 2 Clamps
Step 1: Sawing Out the Roof
mark out a line about 1 to 1.5 inches of the edge a saw it of using the bandsaw. it'll take some time as the wood is pretty thick, take your time
Step 2: More Sawing
saw off both ends, about an inch away from the edge
Step 3: Hollow Out the Centre
hollow out the center leaving 1 inch thick walls with a bandsaw. the not-needed chunk of wood can be thrown away or if not, use in a different project.
Step 4: Sealing the Blade's Entry and Exit
fill the gap with wood glue and then use clamp it together.
Step 5: Sealing
use the ends from step 2, glue them back on with wood glue, and clamp.
Step 6: Hole for the Birds
using a 1.25-inch drill bit, I drilled a hole at the front.
Step 7: Add Roof
Attachment of roof is done here with wood glue, if you would like to, you could use high grit sandpaper to make it smoother.
Step 8: Add Rope
add the rope under the roof to hang it
Step 9: Hang It on a Tree
that's about it, hope you like it
