Introduction: Simple Non-lethal Crossbow
About: I mainly make weapons and bombs but if you ask for it, I'll try my hardest to get it done. Name: Adam Age: 13 Ethnicity: White, British Sanity level: MJDFKJHGSADHSADHSADJH... Yup that explains it Video editing…
This is my first instuctable, its on the crossbow, this is only a prototype so it is not lethal but you can change the amount of power by tightening the strings.
What you will need: 17 inch of hard wood, Bendable wood doesn't matter about the length, 19 inch of sting at first I used wire it was okay but now I use paracord, A handle I used a metal rod that fit into the hole in the wood, 6 inch of bendable thin metal, duct tape if you want it, drill if you have one but if not you can find a big screw and hammer it into the hard wood and that will be your handle.
Step 1: Handle
This step is pretty simple, if you have a drill find a comfortable and drill a hole to fit, if not find a big screw and hammer it into the hard wood, with mine there was already a hole so I just had to make the rod fit.
Step 2: Main Limb (bendable Wood)
First I bent to wood a little and it cracked down the middle which is good as it added more spring into it and it helps attach it to the hard wood, now to attach the main limb to the hard wood put a screw through the bendable wood and into the hard wood and put duct tape over it.
Step 3: String
This is pretty simple, take your string in my case paracord or wire, make dents in the wood to make sure the string stays in place and tie a knot in the string around the wood then repeat on the other side.
Step 4: Trigger
This is the most complicated part, you want some thin bendable metal and follow the picture.
Basically you want part of the metal straight, the middle you want bent around the hard wood, and the top you want 2 dents this will provide safety as when you are not going to fire you should have the string on the lower dent and we you are going to fire you want it on the upper dent to fire you need to release pressure and the string will slide off the trigger.
I hope you have enjoyed and tell or ask me in the comments anything about the crossbow.
I would love some suggestions on what to make next :)
make sure you check out my youtube for more awesome stuff -http://www.youtube.com/user/ARCTICLEADER
