Introduction: Rainbow Loom Single Braclets
You first need your temple. If have any comments comment below.
Step 1: Hook
Then u need your hook. To pick up the rubber bands
Step 2: Rubber Bands
Pick out any colors. Maximum 25 rubber band. Can use as many different color.
Step 3: Starting the Loom
Take the first two colors and place them how I did in the photo. Make a V shape on the template. Make sure the arrow is going up.
Step 4: Continue
Repeat step 3 across the whole template.
Step 5: Continue
Turn the template so it facing you.
Step 6: Continue
Use the hook to take the bottom rubber band and move to the next hook.
Step 7: Continue
Keep doing as said on step 6. Till the end of the Template. This is what it looks like when all colors are on the template.
Step 8: Finish Step
When done u add a "C" clip or "S" clip. To the big part at the end. As seen in picture number 2. With the red lining.Then start piling it off the board. When done with that you can hook ten other end to the "C or S" clip.
Step 9: ALL DONE!!
Now you single rainbow loom is all done!! Enjoy have any question please comment!
