Introduction: Skateboard Construction Course
This is a skateboard made by 3D modeling, which borrows from the actual length and size and adds personal ideas. The details are as follows.
Step 1: Make a Plate
Select a cuboid and change its length to 70mm,width to 20mm and height to 2mm. As shown in the picture.
Step 2: Do the Double Roll of Skatenoard
Select a circular roof, reduce the length as thepole end of the skateboard, and then duplicate it as the pole head of the skateboard, which is slightly longer than the tail and has a larger Angle. Merge the three shapes and set them to red. As shown in the picture.
Step 3: Roughly Make the Wheel Part of the Skateboard
Select a square cone, resizeit so that it serves as a support bridge for the slide pole, resize it with a cylinder as the axle and move it under the slide plate in proportion to its position. As shown in the picture.
Step 4: Make Skateboard Wheel
Select gear to join slip polesupport bridge and merge it. As shown in the picture.
Step 5: Fine Handling of Wheel
Select the tire, add it to the axle alignment merge, and cut off the excess part of the bridge bottom. As shown in the picture.
Step 6: The Wheel Is Combined With the Skateboard and Decorated
Splice and merge the plate and wheel according to position. Select character Settings and place them on the board, align and align. As shown in the picture.
