Introduction: Skateboard Lamp
I had an old skateboard lying around and decided to give it a use again! :) :) I hope you guys enjoy my creation
Step 1: What You Need !
You will need :
Old/ new skateboard
Light fitting
Light bulb
Wire
Switch
Plug
Nails
Hammer
Wood
Piece of aluminum
Aluminum foil tape
Staple gun
Staples
Step 2: Starting
Cut some wood to size so that once it is nailed to the board it will create a gap between the board and the wall that's big enough for the light fitting
Nail them to the board ( might have to remove the wheels)
Step 3: Attaching Light Fixture
Take a 10 cm x 16 cm piece of thin aluminum and bend the edges so no one gets cut it they hold the lamp( when moving it)
Use a staple gun to attach it to the board
Step 4:
Screw on the light fixture on top of the aluminum
Attach the wires (of desired length) to the fixture
Attach switch and plug ( do not plug in! )
Step 5:
Put aluminum foil tape around the sheet of aluminum , this will help reflect light
I used a piece of wire at the top of the board that I nailed down so I could hang it on my wall
Step 6: Finishing Touch
Put in your light bulb
Hang it up and plug that baby in!
I hope I inspired you guys to create a skateboard lamp! =D
I'm always open to questions guys so feel free to ask
