Introduction: Small Cedar Nick Nack Shelf
I got the pattern for this shelf from a flooring Instructable a pretty awesome one at that from here https://www.instructables.com/id/Make-a-Hardwood-Floor-that-looks-3D-from-your-OWN-/ by Vyger
I've used this pattern a couple times the pattern works great for striated and exotic woods with wavy and ribbon patterns
Step 1:
Cut 12 pieces at a 30 * angle i used a table saw and a sled built to cut these sections
Place the width of the board between the fence of your saw and the blade and lock down this will give you the correct width to cut once you make your first edge pass
After the first cut run that edge against the fence and cut the first piece of your boards
Step 2: Gluing
I used a hot glue gun to put this together it holds well on cedars open pore wood
Step 3: Finish
Viola ! finished now my daughter has a shelf for her small goodies
Sand it down a little and give it a nice clear coat to keep that pink cedar color ! I find a flat spray spar urethane works well and protects the wood nicely ....
Enjoy..
Enjoy..
