Introduction: Smart Bluetooth Helmet
About: student at SRM university , Btech mechatronics Loves finding out how things work and trying it myself . Loves anything that's a combination of electronics and mechanical .
It is always difficult to attend an incoming call while you are cruising on you bike.So here is a really easy hack to attend important phone calls during a ride by just clicking a button on your helmet and at the same time always keeping your eyes on the road.Using this hack you can easily attend any phone call no matter where the phone without having to stop your motorcycle and wasting time.You can also hear songs while you are on the move.If you are using GPS,you can hear the directions and instructions loud and clear with this hack.
Step 1: Things You Will Need
1. A full face helmet
2. Any bluetooth audio reciever module with built in battery and mic
3. A 3 mm audio male pin
4. Some thin flat wires
5.Any old headphone
6. A custom made clamp for your particular bluetooth audio reciever
Step 2: Remove the Head Support From the Head Phone
Step 3: Solder the 3mm Earphone Pin to the Other End of the Wires and Seal It With M-Seal
Step 4:
Attach a clamp to the the mouth cover panel and take the wire with the pin through a drilled hole in the panel.Connect the pin to the bluetooth reciever and fix it to the clamp.
Step 5: Attach the Panel Back to the Helmet
Step 6: Attaching Speakers to the Helmet
The speakers are attached to the helmet using double sided tape.Every helmet has an area without foam around the ear region.The speakers are lowered to that area so that it fits perfectly and stays in place.
Step 7: Testing
Wear the helmet and see if it fits perfectly around the ears .If not , adjust the speaker until it does.The bluetooth reciever is turned on using the button on it .The same button can be used for accepting incoming calls and changing the music track.
Step 8: Charging
The reciever should be easily removable from the clamp for charging
