Introduction: Smart Shower
The idea of the project is smart dispensers in the hotel for each cleaner and room when
the guest want some soap for example just by the voice say "soap" and the dispenser well give order to Dc motor put some soap and same idea with other cleaners, for each tank there is a sensor to measure how much left in the tank to send the percentage of the tanks in each room to the Reception to fill the tanks If necessary
Working principle of the selected design
the main idea for a project to use Technology (speech to text )to do it in the python language It is about converting spoken words into text. To make an order to the servo to turn on the machine
We can know the amount of materials inside the machine using a sensor. Send a report to a user to know the actual quantity
Step 1: Raspberry Pi 4 Preparation
The first step we have to do to install the system on raspberry pi
we do that throw raspberry imager
Throw Raspberry pi website we download raspberry imager.
first, go to the Raspberry pi website then, software > our software > Install Raspberry Pi Imager.
this is the link for the website:
https://www.raspberrypi.org/software/
after downloading the imager a window will appear as shown :
then, plug-in SDcard and choose it in the SD card menu.
after choosing the SDcard just click erase to make sure that the SDcard is empty
after that, choose the OS by clicking the operating system button then, choose the OS in the project we choose raspberry pi OS full (32-bit)
finally, unplug the SD card from your pc and plug it into the raspberry pi, and follow the instructions
when we start on the raspberry we have also download python 3 so this is common inside the terminal install it
$ sudo apt update
$ sudo apt install python3 idle3
Install package for pyaudio :
Install pyaudio
sudo pip3 install pyaudio
if you have an issue when you install this package you can use this command :
sudo apt-get update -y
sudo apt-get install -y libportaudio-dev
for update and upgrade raspberry pi buy use this command :
$sudo apt-get update
$sudo apt-get upgrade
$sudo reboot
Step 2: Speech Recognition
the main thing in our project is about speech to text, so we install package (vosk ) in Raspberry pi
Installation and usage
Make sure you have up-to-date pip and python3 versions:
Python version: 3.5-3.9
Upgrade python and pip if needed.
If you have trouble installing, check the output of the following commands and provide it for reference:
$ python3 --version
$pip3 --version
Then install vosk : $ pip3 install vosk
if you want to change pip to be pip3 to install any package we can use this command
$ alias pip=pip3
the advantage of this library can work as offline so we have to download the Model for language and put it in the same place for your code
the link:https://alphacephei.com/vosk/models
Step 3: Install Microphone
This board a highly integrated quad-channel ADC with I2S/TDM output transition for high definition voice capture, which allows the device to pick up sounds in a 3 meters radius.
Features
4 Microphones
3 meters radius voice capture
2 Grove Interfaces
Note: There is no audio output interface on ReSpeaker 4-Mic Array for Raspberry Pi. It is only for voice capture. We can use the headphone jack on Raspberry Pi for audio output
Hardware Overview
MIC: 4 analog microphones
Raspberry Pi 40-Pin Headers: support Raspberry Pi Zero, Raspberry Pi 1 B+, Raspberry Pi 2 B, Raspberry Pi 3 B and Raspberry Pi 3 B+ and Raspberry Pi 4
Install driver
Step 1:Please Make sure to run the latest Raspbian Operating System
Step 2 :open terminal and write incoming command :
$ sudo apt-get update
$ sudo apt-get upgrade $ git clone https://github.com/respeaker/seeed-voicecard.git
$ cd seeed-voicecard
$ sudo ./install.sh
$ reboot
Step 3: Then select the headphone jack on Raspberry Pi for audio output:
sudo raspi-config
# Select 7 Advanced Options
# Select A4 Audio
# Select 1 Force 3.5mm ('headphone') jack
# Select Finish
Step 4: to test the Microphone we have to install audacity, this program can record the voice
the command :
$ sudo apt update
$ sudo apt install audacity
$ audacity // run audacity
Step 4: DC Installing
in this tutorial, I will show you how to connect two motors to Raspberry Pi
part :
An L293 using this module you can control DC Motor, stepper motor, and servo motor. you can check the datasheet by this link :
https://www.ti.com/lit/ds/symlink/l293.pdf
Connecting Dc Motor to Raspberry pi :
The first steps involve wiring up the power through the L293 motor driver
Next involves setting up the GPIO’s for the first Dc motor We will use GPIO 23 (Pin 16, 8 pins over), GPIO 24 (Pin 18, 9 pins over), and GPIO 25 (Pin 22, 11 pins over). Be careful about the ground pin
To add a second motor to this circuit will involve hooking up to the other side of the motor driver. This will be similar to the first side, connecting three GPIO’s to some pins.
You should have the two middle pins (13, 12) connected to the negative rail. The next step is to connect GPIO 17 (Pin 11), GPIO 27 (Pin 13), and GPIO 22 (Pin 15) to the motor stepper. GPIO 22 gets connected to pin 9
Finally, add a power supply to the circuit holder wires to the positive bar and negative bar.
Step 5: Sensor
The sensor we used is TOF10120 laser range
sensor can measure the distance in mm and can be connected to the raspberry pi in two different ways, using serial port or I2C port in this project we focused on I2C port
To connect the sensor to the
raspberry pi using I2C port we are going to use the two address pins from the sensor which is SDA and SCL
Connect the VDD pin to the 3.3V on
the raspberry pi
And connect the ground pin to ground pin on the raspberry pi
Then connect SDA pin to the SDA pin on the raspberry pi
Finally, connect the SCL pin to the SCL pin on the raspberry pi
To make sure if the sensor is connected correctly write this command in terminal
$ sudo i2cdetect -y 1
After typing the scan command, the
sensor address should appear, the default address of the sensor is 52 if this number appears in the bus, we used then the sensor is connected correctly.
But if the sensors default address is 52 and connect another sensor to I2C port this will cause conflict between the sensors then the necessary step is changing address of the second sensor.
We can change the address of the sensor by activate the other busses in the raspberry pi, to activate it follow these steps:
First open up terminal then type $ cd /boot this command will change the directory.
Second type
· $ sudo nano config.txt this command will open configuration text scroll down until you find the I2C activation code, in the next line type:
dtoverlay=i2c-gpio,bus=4,i2c_gpio_delay_us=1,i2c_gpio_sda=23,i2c_gpio_scl=24
this line will activate the bus 4 and use the gpio 23 as SDA and gpio 24 as SCL
if you want to connect third sensor you can activate bus 3 by same steps and write this command:
dtoverlay=i2c-gpio,bus=3,i2c_gpio_delay_us=1,i2c_gpio_sda=17,i2c_gpio_scl=27
this line will activate the bus 3 and use the gpio 17 as SDA and gpio 27 as SCL
you can write the scan command
· $ sudo i2cdetect -y 1 but do not forget to change the bus number that you want to scan
Step 6: Connect Raspberry to SQL Host Server
to sent data from a raspberry pi (python language ) by following steps
step 1: create an account host SQL server https://api.elephantsql.com/
step2: create a database inside the website
step3:write a python code (Test -Insert -Delete ) in your raspberry pi to sent data into your host SQL server account
Step 7: After Running
Obtaining soap using speech-to-text technology and knowing the levels in the cabinets through sensors sent from Raspberry to the user
