Introduction: Snake Plant
To make this Snake Plant you will need the following material:-
PVC sheet white color (0.5 mm) for leaves, 3 mm white Acrylic sheet for pot, Acrylic colors, Super glue, Heat gun, copper wire or any soft wire, gum stick and White Marble chips.
Step 1: How to Make Leaves
Take print out of the leaves (file attached). Paste the print out on the PVC sheet with glue stick. Cut out the leaves, soak the leaves in water to remove the paper. Let it dry, paint these leaves with acrylic paints and let it dry. Now take a leaf place it on sponge. Heat it with a heat gun. check if the leaf is soft then give it the desired shape. Make a hole at the bottom of the leaf so wire can pass through and fix the wire.
Step 2: How to Make a Pot
Take a print out (file attached) and paste it on a 3mm acrylic sheet. Now cut with the help of tools. Join the cutting pieces with super glue.
Step 3: Final Assembly
Pass the leaves wire from the tiny holes of the mesh. Arrange all the leaves and twist the wires and join them together by twisting them in one another. Arrange all the leaves in such a way so they give a natural look. Cover the pot surface with white marble chips. Enjoy the art piece!
