Introduction: Snake Snack Snake
The cost of living in New York is much higher than I thought, and I realized it was time to make a plan to save money.
Snake snack snake is a money-saving lamp. First, you need to set up your goal. The percentage of the led strip lights turn up will still be according to how much they reached the goal. When the goal is achieved, the "snake" will get its "snack", and the snack will turn on.
The material List:
- Adafruit NeoPixel LED Side Light Strip - Black 90 LED
https://www.adafruit.com/product/3635
- Plywood
- Soldering iron and solder
- Wire strippers
- Wires
- Wire cutter
- Insulation tape
- Power adapter
- USB charger
- Hot glue gun
Step 1: Sign Up for IFTTT, Qapital, Adafruit Io
IFTTT: If This Then That
Qapital: savings pot
Adafruit io: send signal to your Feather HUZZAH
Step 2: Create Applet
Follow the instructions to set up your Feather Huzzah ESP8266 wifi board:
https://learn.adafruit.com/adafruit-feather-huzzah-esp8266
https://io.adafruit.com/Rorapanpp/wippersnapper
https://docs.arduino.cc/software/ide-v1/tutorials/installing-libraries#toc3
Create a Snake snack snake feed in your Adafruit IO
Create a new applet on IFTTT:
- Select Qapital
- Select Adafruit IO, setting follow the pictures
- Click Create action
- Finish
